Author Topic: Silly Wheel Alignment Question  (Read 13942 times)
Offline Doms86Shortbed
« on: March 10, 2012, 11:19:52 pm »
Ok guys after finding my front crossmember of my 2wd 1986 C-10 had large rust holes through it, along with the upper and lower control arms. I bought used rust free replacements from various guys off of craigslist and in junkyards. Now since it's frankensteined together it goes down the road but of course needs a front end alignment. I brought it to a place about a mile from my house and the guy said a front end alignment would be $91. Doesn't sound too expensive. So to make a long story short he says I need to come back he needs a special tool and it's not going to be $91 it's going to be $200. I assume the 2wd blazers and vans of 73-87 have the same front end..so it's not like this is an uncommon car, and it can't get much more simple then these basic work trucks. I'm assumed he was trying to rip me off thinking i wouldn't know any better. He seemed like a nice guy at first but then again that's usually how the story goes. Can anyone back him up? I just thought you back the bolts out and shove shims in for the camber, and then the tie rod ends for the toe-in/out.
Offline HAULIN IT
Re: Silly Wheel Alignment Question
« Reply #1 on: March 11, 2012, 08:38:38 am »
I hate to just assume any shop/serviceman is "trying to rip you off" as a first thought, especially if not real familiar with the task...as in, if I was going to have someone fix my microwave or TV.
Did he mention what the "special tool" is & what he was going to do with it? A port-a-power, come-along, ect. could be needed (if for some reason you have bolted the cradle in the frame back on one side & forward on the other) to get the wheelbase even on both sides.
Not sure of anything else at this moment that would make sense. He didn't explain what the "mystery" tool is used for?
I just went through a wheel alignment disaster myself recently that still has me shaking my head. We fixed a 2010 Dodge 4500 4x4 truck with a toolbox bed & crane on it. We replaced the front differential (**Important** solid axle without lockout hubs or axle unlocking collar), the arms that mount it to the frame, steering box & all linkage...along with bumper, fender, ect.
I needed to send it to a shop that does larger truck alignments due to the length & weight.
 I had the guy that fixed it drive it around a bit, he said it drove really well, but the steering wheel was crooked. So I drove it the next night to the alignment shop about 20 miles away. I left a note on the dash saying to do an alignment, mount a new LF tire on the new wheel (in the bed) & dismount the old one from the LF.
I get a call the next morning saying "I can't align it...It's stuck in 4 wheel drive & keeps kicking off the other head when I try to calibrate it." I assure him I didn't drive the truck 20 miles on dry roads in 4 wheel drive & not know it. I also mentioned that there surely wasn't a 4x4 light on the dash driving in the dark that I didn't see. His comment, "No the light doesn't stay on, it goes out with the other lights a minute after you start the truck." So I ask him what makes him think it's in 4 wheel drive? "Because I can see the driveshaft turning when I'm turning the wheel & it's making the otherside turn backwards while I'm trying to turn the driver's side forward." I try to explain to him that it's a new differential & may need someone to hold the wheel on the otherside. He goes on a tangent about "That doesn't work...years ago his friend on his truck, blah, blah & that the transfercase is definitely broken because when I go from 2wd to 4Lo it grinds like something is broken in the transfer case." I ask him if he had the transmission in drive while going from 2wd (across neutral) into 4Lo? His comment, "I'm not sure...I had it running, it may have been."
I politely told him to put the truck outside & we would come pick it up...feeling dumber that I spent 10 minutes trying to make sense out of this "kid".
Long story short...I send a guy to pick it up, the "tech" goes out in the parking lot with him & my guy goes through the gears in transfer case, light comes on in 4x4, doesn't grind going into 4Lo properly, ect. Guy shrugs his shoulders & said something like "It must have gotten unbound bringing it out of the building." & walks back in the building.
My guy drove it another 15 miles or so to another shop. They called me in less than 2 hours saying the truck was done. When the truck comes back, the damaged wheel/tire were still assembled laying in the bed...WOW! I asked for help on 3 things, got one accomplished....They either are going to have to get a new guy or not be in business.
Proceed with caution on your deal, but with an open mind. Lorne
« Reply #2 on: March 11, 2012, 09:05:50 am »
There are no special tools needed to do a front end alignment on one of our trucks.  Same as any RWD GM car.  I think $75 is what I was charged the last time I had it done.  I now do them myself.
« Reply #3 on: March 11, 2012, 09:32:59 am »
     I agree, just had my 74 done at a shop and they let me watch.  No special tools, except they used the alignment rack that it was on and had the plates (sorry for not knowing what it is called) on the outsides of the wheels where the 4 "fingers" type things recorded the camber and toe in/out of the wheels.  They got it really close and the truck drives better even with old tires.
     I personally would check with another shop.
« Reply #4 on: March 11, 2012, 02:01:07 pm »
I bought a Snap On caster/camber gauge on eBay that has a strong magnet and attaches to the hub/rotor.  Key is a level ground, equal air pressures and 2- 1 ft hard vinyl tiles with wax paper sandwiched in between under each front tire.  Jack stands/string/carpenter square/good 4 ft. level and a good tape measure.  There are several Youtube videos showing how to do it and alignment specs on the web.  It is a great way to spend an afternoon helping a buddy out.  I have done several and the results were great...
