Author Topic: Leaf Spring recommendations  (Read 15481 times)
Offline bladerunner
« on: March 12, 2012, 02:17:34 pm »
Looking at replacing both front and rear leaf springs in my 85 K10 SWB.  I want to leave it at stock height.  She rides real bumpy, even on slightly uneven roads. I do some hauling with her, nothing too big, no overloads.  Not looking at doing anything offroad either, pretty much want to keep stock performance. I don't know anything about springs so whatever you can recommend would be greatly appreciated.
85 K10 Shortbed
94 Impala SS
Re: Leaf Spring recommendations
« Reply #1 on: March 12, 2012, 04:09:22 pm »
Call up your closest spring shop and order up stock front, and rear packs. Get new U bolts, and bushings for your shackles as well. They will need to know the diameter of the u bolt wire, the height from bottom of the bolt, to the end of the threads, and the ID of them.
« Reply #2 on: March 12, 2012, 08:49:21 pm »
     I tried to find out what your spring rate is but dang computer is not willing to help.  Like Blazin said, you best bet for a softer ride is find out what the stock spring rate is and have a local shop make you some that are of a softer rate.  That is if you don't mind spending the money.
Offline bladerunner
« Reply #3 on: March 13, 2012, 09:13:54 am »
Well, I am assuming that my springs are worn out being 27 years old, that is why I was thinking of replacing them.  A buddy said I should leave it as that is how old trucks are meant to ride. My shocks are bad too though, but I figure new shocks will stiffen the ride.
85 K10 Shortbed
94 Impala SS
Offline ehjorten
« Reply #4 on: March 13, 2012, 09:29:13 am »
If the ends of your leaves are not worn down and thin, I would recommend taking them apart, cleaning them up with a wire wheel, painting them, putting teflon liners between the leaves and putting them back together with a new center pin.
It will take some time, but it won't cost you much and they will ride a lot better.  Or...www.deaverspringandsuspension.com can do it for you.
-Erik-
Offline Donut
« Reply #5 on: March 13, 2012, 10:03:00 am »
To rough, get the seat re-done.  There is a reason for that thick foam pad.  There is also a rational behind the phrase "rides like a truck".  ;D
beyond that,
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Offline bladerunner
« Reply #6 on: March 13, 2012, 11:19:13 am »
Thanks guys for the advice. Still new to auto mechanics. I don't really have any friends or family who are real gearheads (or the ones I do know are very invested in family stuff to help out, which is good). So I depend on what advice I can get here.
85 K10 Shortbed
94 Impala SS
Offline Jason S
« Reply #7 on: April 13, 2012, 03:45:33 pm »
What did you wind up doing with the springs?
