Author Topic: Wont start  (Read 9079 times)
Offline tiwiz28
Wont start
« on: March 18, 2012, 09:44:19 pm »
I changed steering columns. Everything went smooth everything plugged in and lined up. I turned key and heard a crack and a puff of smoke from engine bay. I found a blown fuse I replaced it and replugged everything into old column  I am getting power to starter and the wire coming to fuse box  but nothing after. The headlights work and turn signals. But nothing else. Any help would be greatly appreciated.
Real Men Wear Bow Ties.
Re: Wont start
« Reply #1 on: March 19, 2012, 02:59:20 am »
what fuse blew? what are you working on?
Re: Wont start
« Reply #2 on: March 19, 2012, 08:52:00 am »
     Need to know truck year/series, and did you swap the same steering assy. or switched to something different with different options ?
Offline awright580
Re: Wont start
« Reply #3 on: March 21, 2012, 02:44:56 pm »
Is it a stick? If it is check for the cable connecting to the clutch it may be disconnected. Once you reconnect it, your truck should fire right up.
Re: Wont start
« Reply #4 on: March 21, 2012, 07:00:12 pm »
autos also have n.s.w. we just need more to be able to start guessing
Offline tiwiz28
Re: Wont start
« Reply #5 on: March 23, 2012, 10:32:20 am »
Its an 1983 chevy k10 350 4sd. The fuse was a 20 amp one on top right of panel. changed fuse still nothing. clutch is hooked up.
