Author Topic: oil pump priming  (Read 6314 times)
Offline str8bloc
  • MISTRESS
oil pump priming
« on: March 19, 2012, 07:33:43 pm »
should i prime my used motor before i put it in. i drained all the oil and bout to fire it up weds.its been sitting for a month
FaTbOy
Offline DustyRusty
Re: oil pump priming
« Reply #1 on: March 19, 2012, 07:53:09 pm »
Well, it wouldn't be a bad idea, esp. if it's used and you've never run it before.  If it's been in your truck all along and just been sitting for a month, you probably will be okay unless your outside air temps. are really low.  I've let my own truck sit for several months and have never had a problem on restart.
Customized by rust.
Offline str8bloc
  • MISTRESS
« Reply #2 on: March 19, 2012, 07:57:45 pm »
no i bought it off a guy it ran i heard it. but ive redone the gaskets and added an intake.thats y i was thinkin to reprime it
FaTbOy
Offline jaredts
« Reply #3 on: March 19, 2012, 08:01:43 pm »
Someone may disagree, but I don't think in that case it is necessary.  It certainly couldn't hurt though.
« Reply #4 on: March 19, 2012, 08:19:56 pm »
Cant hurt. its easier when its out of the truck. remove the valve covers to ensure proper oil flow and make sure you rotate the engine while you prime it.
The only thing I would worry about is poking a hole in the oil pan while installing it and 5 quarts leaking everywhere...
Offline Engineer
« Reply #5 on: March 19, 2012, 08:46:04 pm »
If you already have the distributor out I would prime it.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
« Reply #6 on: March 20, 2012, 02:09:08 pm »
I always prime one if it has been sitting.
Offline Psycho71
« Reply #7 on: March 28, 2012, 04:19:31 pm »
If it was running as little as a month ago, I say don't worry about it. I start my vehicles regularly after sitting a month or more. new starts, and stuff that's been sitting for several months? Yeah, time to prime them. But something that's been sitting for a few weeks is not gonna get hurt.
Offline str8bloc
  • MISTRESS
« Reply #8 on: March 28, 2012, 07:46:08 pm »
well i didnt prime it but it fired ran it 15 mins no prob now time to tune
FaTbOy
Offline 454Man
  • Why Race?
« Reply #9 on: March 28, 2012, 09:37:16 pm »
Sound good!
