Author Topic: A/C Box Sealant  (Read 11132 times)
Offline ehjorten
A/C Box Sealant
« on: March 20, 2012, 10:39:34 pm »
This has probably been covered before, but with my computer psu down, I'm surfing on here with my iTouch and searching is painful on this...so...what is the correct sealant to use between the two halves of the A/C Box and to seal around the openings for the evaporator pipes?
I'm fixing up my '77 box and have everything cleaned, painted and ready to assemble.
-Erik-
Re: A/C Box Sealant
« Reply #1 on: March 20, 2012, 11:02:03 pm »
butyl
Offline ehjorten
Re: A/C Box Sealant
« Reply #2 on: March 21, 2012, 12:20:39 am »
So is it just like butyl rubber tape like for windshields?  Cut it into smaller strips?
EDIT: I got into work this morning and did a search...guess you can buy butyl rubber caulk at almost any hardware store.
« Last Edit: March 21, 2012, 09:01:04 am by ehjorten »
-Erik-
Re: A/C Box Sealant
« Reply #3 on: March 21, 2012, 11:49:52 am »
Offline HAULIN IT
Re: A/C Box Sealant
« Reply #4 on: March 21, 2012, 09:56:56 pm »
A product called M-seal is somewhat like butyl tape, but has a foam core (instead of solid which makes it flatten much easier) works well. Any good autobody supply store or glass shop should be able to help you. It comes in several diameters...I would use the smallest, 4mm I believe it is. Lorne
Offline sonicbluezx3
Re: A/C Box Sealant
« Reply #5 on: June 27, 2012, 07:17:37 pm »
I used regular black RTV... GOBS of it.
1986 Chevy K10 w/ 1983 Cab, 1984 Bed, 1987 Doors and a 6.2 Diesel Swap w/ 700R4 Trans. Truck body completely re-done between 2010 and 2012.
