Author Topic: Stock ride height?? any idea?  (Read 6796 times)
Offline Peteracer
« on: October 12, 2003, 08:36:00 pm »
hi,
I have a 1974 GMC C15 2WD  LWB 350ci. and is having the option (heavy duty suspension front and rear with H/D shocks), but the truck is only having  5 leaves on the rear springs with an aditionnal 6th looking like a heavy load  leaf(thick one).Up front there is  no sway bar  and the regular size  coil springs.
My question is:
The truck is nearly 30 years old, i would like to rebuilt it exactly to the stock specs for the rolling chassis and suspension,But the truck  ride height is too low for me. and i would like to know if any of you guys have a fairly new and similar suspension on your truck and could tell me  how many inches you got between  the ground to the top wheel opening.I would like to know if once i rebuilt my stock suspension  it will stand much higher that it is right now, or simply  be about the same.
thank you very much.
Offline problazer
Sock height??
« Reply #1 on: January 13, 2004, 07:56:00 pm »
Chances are your suspension may sag a bit but not alot unless the truck has hauled alot of heavy crap or has dragged a trailer a considerable portion of it's life. If you are after a stock spec. heigth truck as soon as you rebuild everything with new parts you will have your answer. Raising a truck an inch or two is easy and cheap. I would rebuild first and then decide if you want it up more or not.
