Author Topic: stainless piece removal from cab question  (Read 4444 times)
Offline gto109
« on: March 25, 2012, 12:15:32 pm »
How do I remove the piece of stainless from the back of the cab and corners without damaging them.  There is a truck in the bone yard that has it and i think it will look good on mine. Mine has the set up for it, someone just took it off.
85 Scottsdale k-10 305 700r4,
86 Trans Am 305 350th
06 Dodge Ram daily driver
Offline HAULIN IT
Re: stainless piece removal from cab question
« Reply #1 on: March 25, 2012, 10:43:29 pm »
You will need to reach up inside the cab corner between the inner & outer panels to remove the nuts. I seem to recall the older (wider) pre-'81 having 2 nuts & the later ones only having one per corner, but feel carefully to be sure you got them all. The ends will slide out of the center part with a little wiggling & effort. The long portion is held on with plastic clips. You can look in the end of the molding to figure if you need to pry out on the bottom or top first. If you can't tell, try sliding the trim one way to expose a clip to see it better. With a tap of a hammer or small piece of wood, the clips will come off of the studs. Install on your truck in the reverse order. Lorne
Offline gto109
« Reply #2 on: March 25, 2012, 11:03:45 pm »
Thank you.  I will try this next weekend.
