Author Topic: 1980 Chevrolet c10 exhaust Help.  (Read 17945 times)
Offline colton hicks
« on: March 26, 2012, 10:08:48 am »
I have a 1980 c10 i am about to buy a dual exhaust kit and run dual glasspacks but the kit i am wanting to buy says it fits 1973-1977 2wd i need to know if thats because its just not compatable or just because the kit doesnt include catalytic converters and stock my year model had one. I didnt think there had been an exhaust system change from 77-80 besides the catalytic converter. Would the kit therefore be compatable with my truck?
1980 Chevrolet C10 Silverado, 350 with 4 barrel carter quad recently rebuilt, new shocks, ball joints, bed rails,  steering gearbox, gauge cluster and mirrors. First build/love affair. I recently upgraded from a shadetree to a concrete driveway. Lol
Re: 1980 Chevrolet c10 exhaust Help.
« Reply #1 on: March 27, 2012, 06:11:20 am »
     I assume your trans is the TH350, as far as I know the only difference when looking up exhaust systems for 73 - 80 was the catalytic converters.  I could be wrong, but I believe the frames are the same, the only difference would be 2wd vrs 4wd, and transmission set up's.  (difference in size of transmissions and mounting)
Offline 1980c10
« Reply #2 on: March 27, 2012, 10:43:43 am »
have you checked with your local auto parts store? mine had an entire dual exhuast kit made by hooker with no cats for about $200.
Offline cheeba_c10
« Reply #3 on: March 27, 2012, 01:25:56 pm »
can you tell me what auto parts store that was??  i want to run duals on mine as well.  i saw a complete kit on summit for like $300 i believe...for headers all the way back.  but then i'd have to find somone to install it for me for a decent price.  the local muffler shop said they could do $400 for either magnaflows or flowmasters...but i'm sure that's just dual out muffler and 2 exhaust pipes.  i kinda want to go for true dual exhaust...
always live life following the 6 P's:
Proper Planning Prevents Piss Poor Performance
1980 C10 Bonanza
Offline 1980c10
« Reply #4 on: March 27, 2012, 04:39:51 pm »
I believe it was advanced auto parts. eep in mind if you order it from anywhere you'll need to add shipping, might be about 100  added to the cost.
« Reply #5 on: March 28, 2012, 08:02:36 am »
Thanks for the advice I think ill go ahead and order it. Any advice on a good site for a set of shorty headers?
Offline jaredts
« Reply #6 on: March 28, 2012, 01:45:44 pm »
Why not long tubes if you're doing the entire exhaust?
Offline 1980c10
« Reply #7 on: March 28, 2012, 03:50:26 pm »
I don't know if the exhaust is currently available but check it out anyway. I think it was about two years ago since I checked. Check them for headers as well. Even if the price is higher locally you'll probably come out ahead because you won't have to pay shipping on such large parts.
Offline Jason S
« Reply #8 on: March 28, 2012, 08:21:53 pm »
Dynomax header back system for $127:
http://www.jegs.com/i/Dynomax/289/89007/10002/-1?parentProductId=
Dynomax manifold back system for $147:
http://www.jegs.com/i/Dynomax/289/89006/10002/-1?parentProductId=
Here is an H-pipe kit that will work with the above exhaust:
http://www.jegs.com/i/JEGS+Performance+Products/555/30650/10002/-1
All with free shipping.
I used a similar kit on my '73 and it works pretty well.  It's all mandrel bent tubing. I've put two kits on like these and it takes a little time to fit everything up, but you can get everything set in the way you like it.
« Last Edit: March 28, 2012, 08:23:37 pm by Jason S »
« Reply #9 on: March 28, 2012, 11:06:35 pm »
Sorry if this is a question but is there an advantage to running long tube headers rather than shorties? This is my first build and im not familiar with performance exhaust. And to jason s is that kit weld free or does it need to be welded together? I am a good welder but I dont have a shop  or decent mig or tig setup seeing as im still in high school. So I need a bolt up kit. It really limits my choices.
Offline jaredts
« Reply #10 on: March 29, 2012, 08:15:57 am »
Long tubes give better performance, shorties aren't much of an improvement over factory cast iron.  Most kits are designed to be clamped together.  The header back kit he posted comes with 6 clamps so I don't think its an exception.
« Reply #11 on: March 29, 2012, 09:50:56 am »
Thanks this is the exact reason I use this site. Im new to restoration and mods so without your help I would've never found that setup or known to go with long tube headers. Im going to order it today after school.
Offline Jason S
« Reply #12 on: March 30, 2012, 08:33:04 pm »
Jaredts correct about the kit being weld free.
They'll come with hangers, u-bolts, etc.  With the exhaust crossover included, the kit I installed has a quite a few clamps for now.  I'll weld everything up later when I have my welding equipment setup again.
Offline cheeba_c10
« Reply #13 on: April 03, 2012, 12:09:46 pm »
this is great info...and colton hicks asked the exact question i was gonna ask in reference to if this kit could be bolted on.  this seems like something i could do in the driveway with some jack stands.   so with this kit...the only other thing i would have to purchase would be the 2 mufflers?  and...where are the exits for the exhaust?  is it in front of the rear tire of behind?  i have an 8 ft bed...so i kinda assume in front...
1980 C10 Bonanza
Offline Jason S
« Reply #14 on: April 14, 2012, 03:39:11 pm »
My kit exited at the stock location, which would be behind the wheels.  Here is a post of what mine looked like:
http://forum.73-87chevytrucks.com/smforum/index.php/topic,22068.0.html
