Author Topic: Ful float axle bearing pre-load?  (Read 7726 times)
Offline 1976er
« on: March 26, 2012, 09:34:02 pm »
No luck in the search department (too wordy?); never seems to be much help.  Anyhow, 1976 3/4 ton full float axle, doing rear brake job.  What is the proper way to set up the wheel bearings?  I have never done a brake job of this nature and want to be right the first time.  Anything else usually need to be replaced while I am in there?  I appreciate any and all input I can get from you all.  Thanks much
Re: Ful float axle bearing pre-load?
« Reply #1 on: March 26, 2012, 10:03:53 pm »
You want to coat the bearings with the same oil your running in the rear axle before you install them into the races. Then spin them around a little in the races.
I tighten them until the drum is hard to turn, then back it of till it spins free, but no looseness, or play.
Offline 1976er
« Reply #2 on: March 26, 2012, 10:23:51 pm »
Sounds good.  Do I not repack the bearings with grease or are they lubed by axle oil?  Thanks again
Offline bigchevyc30
  • the pig
« Reply #3 on: March 26, 2012, 11:05:39 pm »
the book i got on these trucks shows to pack them with grease so i did what it said
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
Offline 1980c10
« Reply #4 on: March 27, 2012, 10:56:32 am »
I tighten them until they feel tight and try to push the washer behind the bearing side to side with a screwdriver and loosen them if I can't and tighten them if I can easily. Kind of find the middle point to where I can barely move the washer. I will also carefully inspect the bearings before re-packing for any wear at all or just install new bearings with the brake job.
Offline 1976er
« Reply #5 on: March 27, 2012, 11:48:48 am »
Thanks all, I appreciate the help.  I really should buy a manual I guess.  But everyone here is really great!  THANKS
« Reply #6 on: March 27, 2012, 10:44:41 pm »
They are lubed with gear oil from the rear end. No need to pack them. thats why I mentioned wetting them with gear oil before installing them. Oil provides less rolling resistance than grease.
