Author Topic: How do you hook up a 2 step rev limiter?  (Read 12535 times)
Offline sbx22
  • 1974 1/2 ton 350 sbc
« on: March 29, 2012, 11:05:21 pm »
I have the MSD 6AL-2 right now. I want to activate the 2-step and do some launches. I've been doing some research, reading the manual, but what the heck is a trans-brake and what is a line lock solenoid? Where are they located? Can someone tell me step by step how to wire this, and also where I can find these on my truck? 74 C10 350/350.
Offline HAULIN IT
Re: How do you hook up a 2 step rev limiter?
« Reply #1 on: March 30, 2012, 05:54:20 pm »
Unless someone added them, you don't have either one. They are not factory items. The instructions should be rather clear. Lorne
Offline codyC10kid
« Reply #2 on: April 18, 2012, 07:44:12 pm »
the transbreak is a aftemarket part a stock tranny doesnt have...the transbreak locks the forward gear and the reverse gear together and when a transbreak switch is let off it lounches like a rocket....line lock i have no idea what that is
« Reply #3 on: April 18, 2012, 09:26:53 pm »
A tow truck I used to operate had a line lock on the rear brake line.  You would stop and flip the lever then let off the brake.  It worked quicker and held better than the parking brake.  I am assuming that it what they are...
Offline HAULIN IT
« Reply #4 on: May 15, 2012, 10:08:09 pm »
Zieg, Just a "for thought" conversation. We put the linelocks on the front axle of our wreckers & flatbeds. With the driveshaft or back wheels having the E-brake, this gives you 4 wheel brakes. This is good for several reasons. If you pulling a vehicle using the winch, you have 4 friction areas on the ground...this is real helpful on slippery roads. Also the back axle is most times closer to the edge of the road where it's more likely to be slippery, light gravel, ect. so when using the front brakes...they are in the middle of the road. With the flatbeds, you can take the weight off of the back axle if the bed is angled a bit too much...on a slippery day, the truck can slide ahead. Once it starts moving it's not always pretty. Lorne
« Reply #5 on: May 16, 2012, 06:16:19 am »
     I have also done this on jeeps and earlier broncos in my off roading days, sometimes the rear wheels are not always planted enough to hold a vehicle alone when you had to get out, having the front axle (on a 4wd in 4wd) or driveline with a line lock could mean the difference on whether your vehicle stayed where you parked it or not.
