Author Topic: I want to install a diesel engine 6,5 instead of 6,2  (Read 34236 times)
Offline valyidol
« on: March 30, 2012, 01:29:33 pm »
Hi! I'm from Russia and my English is bad. Sorry.
I have Suburban-2500 1988 4x4. And I want to install a Hummers diesel 6,5 turbo instead of 6,2. Tell me pls, what have I do to this diesel install? Or this does not make sense?
Re: I want to install a diesel engine 6,5 instead of 6,2
« Reply #1 on: March 31, 2012, 03:50:04 am »
what does your truck have in it now?
Offline valyidol
« Reply #2 on: March 31, 2012, 04:21:50 am »
Now my truk have diesel 6,2
Offline ralphhemi
« Reply #3 on: March 31, 2012, 05:53:35 am »
Welcome from Vt  I think it will bolt right in . not sure what is different. i will ask my diesel man Andy and get back to you.
Ralphhemi
« Reply #4 on: March 31, 2012, 10:18:17 am »
      I would think it would be a easy swap.  Give some time for the diesel experts on here to see your post and they will chime in.  Welcome from California, US.
« Reply #5 on: March 31, 2012, 10:57:29 am »
Welcome to the site. What is the engine sitting in the pic? It looks like a heavy duty shipping crate.
Offline valyidol
« Reply #6 on: March 31, 2012, 11:10:34 am »
No, this diesel Hammer on that's for sure. There is a sticker on it
« Reply #7 on: March 31, 2012, 11:26:19 pm »
I meant "what is the engine attached to?" The green box...
Offline junkman.
« Reply #8 on: April 01, 2012, 01:25:06 am »
do it i would swap some of the 6.2 parts over to your 6.5 the intake and maybe pulleys a/c pump p/s pump etc.  also looks like the turbo is in back that won't fit were its located
the only thing i can think that might be a problem is the injection pump shut down solenoid it may be 24 volts  you should be able to use the one off your 6.2 note just the solenoid
also read the article on 6500
« Last Edit: April 01, 2012, 03:17:22 pm by junkman. »
Offline valyidol
« Reply #9 on: April 01, 2012, 01:37:31 pm »
My English is bad!  ;)
Offline junkman.
« Reply #10 on: April 01, 2012, 03:13:16 pm »
Welcome to the site. What is the engine sitting in the pic? It looks like a heavy duty shipping crate. x2
Its a military secret  and you can't have it  :-X
it looks like a engine stand is a sipping box  do i win prize    ;D
dose the box come with the engine
« Last Edit: April 01, 2012, 03:41:06 pm by junkman. »
Offline fitz
« Reply #11 on: April 02, 2012, 12:19:41 pm »
That's the shipping crate that the US Military ships these motors in.
Offline Mr Diesel
  • Aaron
« Reply #12 on: April 03, 2012, 12:17:04 am »
If your suburban has an A/C (air conditioning) box the turbo will probably interfere with it. Might have to cut a notch or something there. Everything else pretty much bolts right up.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
« Reply #13 on: April 03, 2012, 05:42:02 am »
     I believe it is a military hummer 6.5 that he wants to put into his truck.
Offline valyidol
« Reply #14 on: April 03, 2012, 04:14:11 pm »
I worry about a control system of the engine and the fuel pump.Is there this diesel engine an electronic control system?
