Author Topic: Going Back to a 700R4  (Read 12610 times)
Offline Butalla
« on: March 31, 2012, 08:39:42 am »
I have an 86 C10 SB that originally had a 305ci engine code H with a 700R4.  When I bought the truck, it had been switched to a 350ci with a 72 Quadrajet and a TH350 trans.  I bought an 85 700R4 to put into it.  My question is whether or not I can use the existing ECM that is still under the dash?  Will it be looking for signals from the engine or carb that are no longer connected and then not control the TCC correctly?  What sensors do I need to make sure I still have and where are they located?  I'd like to make sure I know what I'm getting into before I start.  Thanks in advance for any input!
Offline Jason S
Re: Going Back to a 700R4
« Reply #1 on: March 31, 2012, 08:54:46 am »
Welcome to the site.
Have you looked into the harness adapters from Painless, B&M, etc. that will allow you to wire for the lockup torque convertor?
« Last Edit: March 31, 2012, 08:56:50 am by Jason S »
Offline Butalla
« Reply #2 on: March 31, 2012, 09:01:48 am »
I have seen them and figured that they would be plan B if I can't use the original ECM.  I can't really afford to spend any more than I need to right now.
Offline Jason S
« Reply #3 on: March 31, 2012, 09:19:09 am »
Here is a link for "typical" wiring.  http://www.73-87chevytrucks.com/techinfo/wiring_diagrams/81-87_computer_control_wiring.jpg
There are people on here a whole lot more familiar with the 80's ECM that will be able to chime in, just give them some time.
Offline Butalla
« Reply #4 on: March 31, 2012, 10:41:52 am »
Thank you, that should be helpful.  I'm in luck in the fact that all of the wiring was left in, I just need to see what is unconnected.
« Reply #5 on: April 02, 2012, 05:24:43 pm »
700R4's are NOT controlled by the ECM.  Lockup of the converter is all you have to worry about.  Do a search there was a thread on this recently.
Offline Butalla
« Reply #6 on: April 03, 2012, 07:18:54 am »
I understand that the ECM does not control the shift points of the 700R4.  However, if I understand correctly, it does control the torque converter lockup.  What sensors is it looking at to do this?  If anyone could please answer this i would appreciate it.
Thanks
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #7 on: April 03, 2012, 07:44:44 am »
I've been told by transmission shops before that they can set the trans up mechanically to lockup the converter so it wouldnt need any electrical wiring for it.
Offline Butalla
« Reply #8 on: April 11, 2012, 10:09:25 pm »
Alright, I've found out that the ECM is looking for the throttle position sensor and pulses from the distributor to determine TCC lockup, neither of which I have anymore.  Therefore, i think I'll have to create the external circuit.  Better to know now that find out when I'm into it already.  It doesn't look terribly complex.
Also, Anyone know what the vacuum sensor is on the firewall just to the right of center?  It doesn't look like it's connected to anything.
« Reply #9 on: April 12, 2012, 06:29:28 am »
     Do you have a pic, or can you describe the shape color of the sensor ?
Offline Butalla
« Reply #10 on: April 12, 2012, 12:41:37 pm »
It is black, cylindrical with the vacuum port facing toward the center of the firewall and the electrical connector at the opposite end.
Offline 454Man
  • Why Race?
« Reply #11 on: April 12, 2012, 07:00:35 pm »
This one?
Sent from my T-Mobile G2 using Tapatalk 2
Offline cvbear
« Reply #12 on: April 12, 2012, 08:22:34 pm »
That looks like the sensor for the anti-knock system.  You can safely remove it if you want to clean up the engine bay.  It is probably unhooked already but if not there is a thread on the board with detailed instructions.
Offline Butalla
« Reply #13 on: April 12, 2012, 10:02:19 pm »
Yes, that's the one.
Thanks
« Reply #14 on: April 13, 2012, 06:05:47 am »
     See, it does take a whole village.   ;D
