Author Topic: 14 bolt question?  (Read 14176 times)
Offline SK468
14 bolt question?
« on: February 17, 2004, 10:46:00 pm »
Hello everyone I have a 14 bolt and it's an open differential, what's the cheapest way to get a posi or locker in there? If you know of sources that would be helpful.Thanks in advance!!
Offline 73K20
Re: 14 bolt question?
« Reply #1 on: February 18, 2004, 08:55:00 am »
Detriot locker is the cheapest to get, but are getting more expensive.  I believe that you can get one new for about $350 if you shop around, they were about $300 a year ago.  It replaces the spider gears inside an open differential.  If you have a carrier from a 14 bolt that originally came with a gov-loc then you will need to find a new carrier.
*edit* I forgot to mention that this is for a full floating 14 bolt only.
1973 K20 - 350/465/205
Edited by: 73K20 at: 2/18/04 8:56 am
Offline SK468
14 bolt question?
« Reply #2 on: February 19, 2004, 12:29:00 am »
Are you talking about the powertrax locker? That's the one that goes inside your existing differential, last I looked through Jegs they wanted $450 for it. If you know of a cheaper source for one I would be interested, thanks for the help!! Ohh and my 14 bolt is an open diff and it's a full floater as well.
Offline 73K20
Detroit Locker
« Reply #3 on: February 19, 2004, 07:52:00 am »
Check out the No Spin/Detroit Locker.
Offline SK468
14 bolt question?
« Reply #4 on: February 19, 2004, 02:40:00 pm »
Thanks!!!!
