Author Topic: changing cam in 383  (Read 4036 times)
Offline 305chevy c-10
changing cam in 383
« on: April 01, 2012, 06:30:44 pm »
my cam is a 268 duration 215@.050 lift with 1.5 rockers .490 lift 110 lsa .i was thinking of going with a howards 180-325-10 ,180-325-08,180-255-10 .the specs on these cams are usually based on 350 cid ,so i was wondering if anyone of these would be a lot better than what i have .if a cam requires a 2500 stall in a 350 will it still need that much stall in a 383 ****Summit Racing Part Number  HRS-180325-08
Cam Style  Hydraulic roller tappet
Basic Operating RPM Range  2,000-5,800
Intake Duration at 050 inch Lift  225
Exhaust Duration at 050 inch Lift  233
Duration at 050 inch Lift  225 int./233 exh.
Advertised Intake Duration  278
Advertised Exhaust Duration  286
Advertised Duration  278 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio  0.525 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio  0.530 in.
Valve Lift with Factory Rocker Arm Ratio  0.525 int./0.530 exh.
Lobe Separation (degrees)  108
Camshaft Gear Attachment  3-bolt
***Summit Racing Part Number  HRS-180325-10
Basic Operating RPM Range  2,200-5,800
Lobe Separation (degrees)  110
Summit Racing Part Number  HRS-180255-10
Intake Duration at 050 inch Lift  231
Exhaust Duration at 050 inch Lift  235
Duration at 050 inch Lift  231 int./235 exh.
Advertised Intake Duration  284
Advertised Exhaust Duration  288
Advertised Duration  284 int./288 exh.
Intake Valve Lift with Factory Rocker Arm Ratio  0.510 in.
Valve Lift with Factory Rocker Arm Ratio  0.510 int./0.530 exh.
Heartbeat of America yesterday's cheverolet
18T5C10
Offline Jason S
Re: changing cam in 383
« Reply #1 on: April 01, 2012, 09:31:55 pm »
Just looking quickly, I think you may be pushing the powerband up in the rpm range.
You ask would "would any of these be a lot better than what I have."  That really depends upon what you are trying to achieve and what other components you have to work with. Do you want brute low end torque for towing and don't care about top end or do you want a street machine that you can take to the drag strip?
Cam selection will depend upon what you want to achieve (such as a tow rig vs. street machine), transmission, rear end ratio, exhaust system, heads, rocker ratio, etc.
Have you talked to the cam company about what you want and what you have?
