Author Topic: NP203--Anyone know what this is?  (Read 8620 times)
Offline 1976er
« on: April 04, 2012, 09:23:51 am »
On a few of the mid-70s pick-ups I have noticed something different.  I recently had to rebuild my 203, the donor TCase, on the extreme right side of the chain case portion there are two external holes for a mount of some sort.  I went to the scrape yard and found this "mount"; it is a rod that bolts to those two holes and then runs up to where the tranny bolts to the engine block and is secured by one of those bolts (tranny to engine block).  Is there a purpose for this "rod" and if so what is it?  I have noticed several other vehicles with the holes for the rod, but it is not installed.  To me, when looking at it installed it does not appear to have any function; seems too light for any kind of support.  Ideas???
Offline snibook7537
  • Vince Ziolkowski
Re: NP203--Anyone know what this is?
« Reply #1 on: April 04, 2012, 09:47:10 am »
I have seen them too. I kinda thought the same thing, they were too dinky to actually do any kind of support. Id be curious to see if they had a different role or just a dinky support piece.
1984 Fiero se pwr windows Holley TBi, cam, 86 5spd
1987 GMC V3500 350 TBi 4spd 205 t-case
Shoulda never sold:
1976 c-10 beater 250-6 4spd no pwr steering, brakes. Recycling truck
« Reply #2 on: April 04, 2012, 06:26:17 pm »
It provides stability to the transfercase/drivetrain.
« Reply #3 on: April 05, 2012, 06:57:14 am »
     Not that it is much, but it is for support.
Offline 1976er
« Reply #4 on: April 05, 2012, 10:15:54 pm »
Being that I have only saw 1 truck with it installed (scrape yard), I won't worry about installing one.  Thanks
« Reply #5 on: April 06, 2012, 06:05:00 am »
I have seen several 208 cases crack over the years, none of them had this rod installed. Have been told by a guy that rebuilds transmission, and transfer cases that this prevents them from cracking. From what I have experienced in my Blazer wheeling with the a 208 I think that if the front suspension compresses all the way, and the front shaft slip yoke bottoms out. It pushed backward on the case, and cracks it. Or in my case with the Blazer broke the right side of the transfer case completely off!!!  :o
As far as a 203 they are cast iron vs the aluminum 208. I would think they would be less prone to cracking.
Offline Engineer
« Reply #6 on: April 07, 2012, 07:07:44 pm »
I am running a 550HP big block in my 4x4 sled puller, and I don't have one.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
