Author Topic: Truck is leaning to one side ???  (Read 36284 times)
Re: Truck is leaning to one side ???
« Reply #15 on: April 28, 2012, 08:08:25 am »
THats a Head scratcher......   all you can do is get in on a level surface, and break out the tape measure and start measuring all kinds of supsension points comparing left and right sides.
      You would have to check not only the metal stuff, but all the rubber bushings, air in tires and heights, the actual height of the springs under load, etc, etc.  It would take you some time and you might find more than just 1 item is contributing to the loss.
Offline tpull123
« Reply #16 on: April 28, 2012, 04:26:34 pm »
Agreed, axle centerline is a key suspension point.
1978 Frame w/ Cummins Diesel, 85 cab and front end, and time well wasted....lots of it!
Offline 1987V204X4
« Reply #17 on: May 11, 2012, 02:56:44 pm »
Ok I removed the 4" superlift and installed a set of HD 4"leafs in the front, along with new ubolts and socks on all for corners. The truck still has a sag on the driverside. It's not as bad as it was with the 4" lift but it is still defiantly leaning to the left. WTH ????? The only other thing I can think of is the body bushings. What do you think?
« Reply #18 on: May 13, 2012, 12:35:56 pm »
     You can keep replacing parts until everything is new and it might still lean, you have to get a standard base to work from and find out why it is leaning, otherwise you are just chasing your tail in a circle.
