Author Topic: Biggest tire under a stock suspension 3/4 ton 4x4  (Read 10724 times)
Offline 1987V204X4
« on: April 04, 2012, 03:25:13 pm »
What is the biggest tire that will fit under a stock 87 ¾ ton 4x4
I'm wanting to remove my Superlift kit and my 315-75-16 tires and go to a lower heigth.
Offline firefighter
Re: Biggest tire under a stock suspension 3/4 ton 4x4
« Reply #1 on: April 04, 2012, 03:36:45 pm »
Some of this question can depend on the width of the tire and the backspace of the rim.
I do not have an exact answer as my truck has bigger tires but I'm sure others that have researched this will answer.
You want to remove a lift kit? Isn't that kind of like getting a vasectomy? Removing some of your manhood?  :o
Seriously, Just funnin with ya !!!!   :)
Offline 1987V204X4
« Reply #2 on: April 04, 2012, 06:14:24 pm »
Yeah that does sound pretty dumb!!!  The reason I was thinking of doing this was to plow snow with it. But I've re-thunk it over  ::) and I'm going to just keep the 4" lift. Then after I ware out the 315-75-16 Fearce MT's I might go down a tire size or two with a set of AT's of some kind??????
« Reply #3 on: April 05, 2012, 06:07:12 am »
     I can see your thinking on the plowing snow, but I really don't think it would matter much.  The best thing like you said is when you wear out the tires you have go to a lower tire and I think it would do better.
     A member on here named Blazin (I believe I am correct) does plowing with his truck, he would be a good one to ask.
Offline Edahall
« Reply #4 on: April 05, 2012, 08:56:18 am »
305/70/16 -  Kind of an expensive size though to buy.
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #5 on: April 06, 2012, 07:53:57 pm »
Don't know how different the height will be from your truck to mine, but my 78 C20 with a 2" lift, max size is a 275/70R18 and I had to nip a bit off the front bottom of the wheel openings in the front fenders.
