Author Topic: lower rear end of 78 chevy step  (Read 6663 times)
Offline 78steprider
« on: March 27, 2004, 03:55:00 pm »
i have a 78 chevy step and i am wanting to lower rear end by removing leaf springs (4 each side) and using shackles. How and which leafs do I remove for a combined 4 inch drop??
Offline roundedline
Re: lower rear end of 78 chevy step
« Reply #1 on: March 28, 2004, 08:05:00 am »
I assume you have a heavy Duty rear suspension with more than 4 leafs.  I wouldn't remove more than 3 out of a HD leaf pack.  You can't get 4" of drop out of removing that many leafs and the ride not severely suffering.  You best bet is to get a shackle/hanger kit.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 78steprider
lower rear end
« Reply #2 on: March 28, 2004, 09:53:00 am »
im not really sure if i do have a hd rear end or not. but i do have four leaves on each side. Someone told me I could remove a certain leaf and put a shackle set on and that would give me a 4 inch drop. Just wondering if any knew "which one" or the best candidate for removal so that can happen. I am also lowering the front 2" with the use of drop springs. I have all new drop shocks (nitro) to assist. Thx for the reply!
Offline bigblock73
  • Yeller
Re: lower rear end
« Reply #3 on: March 29, 2004, 11:31:00 am »
a shackle and hanger kit is around $100...I would go that route.  It will give you your 4" drop.
Unless you have HD leafs (8 leafs I believe), I wouldn't remove any leafs.
Jeff
'73 swb 2wd
73-87.com
