Author Topic: EGR  (Read 12249 times)
Offline jaredts
Re: EGR
« Reply #15 on: April 09, 2012, 09:15:41 pm »
Just re-read, and I see what you're saying.  Presumably there's vacuum at the egr all the time, then.  Sorry to interrupt, carry on guys.
Re: EGR
« Reply #16 on: April 10, 2012, 12:07:52 pm »
Take your test light and connect it to B+, touch ground and verify it lights up. Now with the engine running touch the terminal that had zero volts and see if it lights up.
Offline mpullen66
Re: EGR
« Reply #17 on: April 10, 2012, 06:23:23 pm »
I dont have a test light. only have mulit-meter.
I had a chance to mess with it today.
1. There is good vacuum at the throttle body
2. The solenoid opens and pulls vacuume when accelerating
3. The EGR valve opens when I pull vacuum on it but it doesnt stay open. When i pull vacuum it opens for a split second then closes again.
4. I left the EGR valve off and started the motor, then throttled it a bit. I also sprayed carb cleaner in the EGR holes (hope that wasnt stupid), then started and throttled a bit.......no change when all was reconnected.
Sorry to be a pain. Im at a loss
Mike
1987 LWB,2WD,350,700R4  times 2
Re: EGR
« Reply #18 on: April 10, 2012, 06:59:03 pm »
Start over - when the engine is running like crap, pull the vacuum hose off of the EGR valve and see if A) it runs better and B) if there is vacuum there.
