Author Topic: did i get bad fuel from a station?  (Read 8139 times)
Re: did i get bad fuel from a station?
« Reply #15 on: April 12, 2012, 06:24:08 am »
     Glad to hear you got it running right again, now others can know to check the solenoid first.
« Reply #16 on: April 12, 2012, 03:59:23 pm »
You said you pulled the vacuum hose off of the EGR and that it made no difference but then you replaced the EGR solenoid and it's fixed. If the solenoid was bad (stuck open) it would allow vacuum to the EGR when you don't want it there. Unplugging the vacuum hose removes the vacuum source.
