Author Topic: 10 bolt front  (Read 2611 times)
Offline 1979C20
  • Kyle Taulton.
10 bolt front
« on: April 14, 2012, 08:19:29 pm »
I have a 10 bolt front axle that I got off craigslist. The driver side was converted to 8 lug. The passenger side is missing everything but the knuckle. I've done research and have found that my calipers and brakelines will work on the 10 bolt 8 lug rotors. 1/2 ton spindles work with the 3/4 ton rotors. I have a friend with the parts I need, all but the caliper backing/mounting plate. What I'm trying to figure out is, can I use my caliper plate from my 2wd suspension and drill some holes in it for the 10 bolt?
