Author Topic: Holley 750  (Read 4260 times)
Offline Bitzer!
  • Smiles per gallon
Holley 750
« on: April 15, 2012, 03:18:02 pm »
Hi guys,
Either a silly question, a senior moment or I have a problem!
The 454 fires up lovely on the key, I have the throttle cable hooked up to the front linkage.
The two rear barrels aren't taking juice unless I opererate the linkage manually. Am I just missing a spring or should they run on vacuum?
cheers as always
Andy
1979 GMC CrewCab  C20 1t
Offline ralphhemi
Re: Holley 750
« Reply #1 on: April 15, 2012, 07:55:41 pm »
If you have a mechanical 4 barrel ,then it will be a double pumper 2 accelerator pumps , if you have vacuum secondaries  they will not open until under load
Ralphhemi
Offline Bitzer!
  • Smiles per gallon
Re: Holley 750
« Reply #2 on: April 16, 2012, 11:08:08 am »
Aha that would explain it!
Yes they are vacuum, can I / is it worth it to change them over to fully mechanical?
cheers
Re: Holley 750
« Reply #3 on: April 17, 2012, 06:20:24 am »
cheers
     It would be worth it if you want to stand there and throttle the truck to wide open to see the secondaries open.  Otherwise when you drive it you will be able to tell if they open.  They work just fine being vacuum operated as long as the vacuum hoses are hooked up and you have good vacuum.
Offline Bitzer!
  • Smiles per gallon
Re: Holley 750
« Reply #4 on: April 17, 2012, 09:41:39 am »
Cheers Bake, I guess I'll leave em as they are. All new vacuum hoses and tight fit so should be fine. One less thing to worry about!!
Offline TexasRed
Re: Holley 750
« Reply #5 on: April 17, 2012, 09:30:55 pm »
Howdy Bitzer! Have you seen this regarding holley carbs: http://www.bob2000.com/carb.htm
Offline Bitzer!
  • Smiles per gallon
Re: Holley 750
« Reply #6 on: April 18, 2012, 04:28:10 pm »
Cheers TexasRed
I hadn't seen that but it's well and truely saved!!!
