Author Topic: Truck leaning  (Read 6993 times)
Offline kickr69
Truck leaning
« on: May 05, 2004, 06:40:00 pm »
I have a 76 chevy stepside pickup and the truck leans to one side 1" lower than the other side.  I have replaced the shocks, front coils and rear shackles ( i lowered the truck 2" that is the reason i replaced the shackles). I think it might be the rear leaf spring but would the leaf cause the whole truck to lean?  I don't want to start replacing stuff i dont have to.  thanks
Offline oscarone
Re: Truck leaning
« Reply #1 on: May 05, 2004, 10:26:00 pm »
You see that on a lot of old Chevy trucks.  It is probley one of two things.  Either the springs are old and sagging, or, the bushings are shot.  Check the bushings first as they are easy to replace, and, not expensive.  You may be able to check your springs by laying a straight edge across the top and measuring the distance from the straight edge down to the bottom of the spring at the center.  Where they mount to the axle.  Compare the left and right sides.  If it is the springs you can either buy a new set, or, I think you can have the old ones "re-curved".  If it is not the supsension you may check fo a bent frame or shackle problem.
Offline roundedline
Re: Truck leaning
« Reply #2 on: May 06, 2004, 10:24:00 am »
Spings settle at different heights.  You will not get each side perfect, but you can get it close, but you will either have to raise the low side with a rubber spacer, or trim the spring on the high side.  (cutting a little at a time and putting it back in and driving it to check)  Measure your newer car, and you will find variances in them also.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline RSBAD454
Re: Truck leaning
« Reply #3 on: May 07, 2004, 09:30:00 am »
check bushings......cab mounts etc......i hav eyet to see a leaf spring sag on one side, unless the truck was beat on like a red headed step child.
Toys are my game
http://
