Author Topic: Full time 4x4,want 2wd  (Read 40941 times)
Offline codyC10kid
« on: April 18, 2012, 06:52:51 pm »
IM BACK  ;) i havent been on in a lonnng time,
 any way i have a 77 K10 350 th350 full time 4x4 12 bolt rear end GM 10 front
i took the front drive shaft off to save gas and puts around town,front drive shaft is off and i cant move,jacked the back tires up put it in drive and they move but need to tromp a lil,but they all move with the front hooked up..am i doing sumthing wronge or is my transfercase broke(i doubt but never know)
« Last Edit: April 18, 2012, 06:59:30 pm by codyC10kid »
Offline heavychevy91
  • '86 Chevy K20
Re: Full time 4x4,want 2wd
« Reply #1 on: April 18, 2012, 07:57:26 pm »
Your t-case, a NP203 is an all wheel drive t-case. If you remove the front drive shaft if will act as an open rear end with one tire off the ground. You need a part time kit for the 203 and preferentially locking hubs.
Part time kit: http://www.summitracing.com/parts/MMK-501/
And the hubs: http://www.summitracing.com/parts/WRN-9790/
A variety of other hubs will work but those are lower on the cost spectrum and work well.
« Reply #2 on: April 18, 2012, 08:54:40 pm »
Or lock the transfer case in 4 hi loc
Offline codyC10kid
« Reply #3 on: April 18, 2012, 10:26:05 pm »
Hi loc is it all the way forward or all the way back....im not used to my truck i just got it running while back and replaced all the bady parts and lost the shift indicator that tells me where 4low loc and N is lol
« Reply #4 on: April 18, 2012, 10:31:43 pm »
Not a 4x4 kind of guy and the last time I was in a truck with a full time transfer case was my buddy's 78 K5 Blazer over 26 years ago.  I just know if I ever went to a 4x4 that would be my choice.
« Reply #5 on: April 19, 2012, 05:34:53 am »
     All the way forward/up toward front of truck.  This will work for now but I strongly suggest you look into a part time kit and locking hubs for the long run.
Offline codyC10kid
« Reply #6 on: April 19, 2012, 11:41:55 am »
it already has the front locking hubs....the person i got it from died then it went to his cuzin and he dosnt know anything about the truck,the reason i have it is becouse he rolled my 4-wheeler and toataled it out so he gave me the truck...but its a 1977 K10 full time 4x4 lock out hubs up front sits kinda high for no lift,it has 33,s on it now when i got it there was leaf springs in the back,so i dont know what all has been replaced or anything...i replace the front pinion seal in the diferental and the parts guy said it was for a 3/4 pickup But my rims only have a 6 bolt patern...this truck is really confusing me :o
« Reply #7 on: April 19, 2012, 12:18:18 pm »
Putting lock out hubs on a full time transfer case that hasn't gotten the part time kit in it will not allow it to move with the driveshaft out. There is a differential in the transfer case and it sends power to the end that slips, ie the end that doesn't have the driveshaft in it.  The lock lever engages a collar and locks both ends together.
Offline jdl71
« Reply #8 on: April 19, 2012, 08:40:00 pm »
Hi Loc is all the way back, against the seat. Lo Loc is all the way forward.
« Reply #9 on: April 21, 2012, 05:57:56 pm »
     My bad, got it backwards.
Offline Jason S
« Reply #10 on: April 22, 2012, 11:04:13 pm »
Just order a part-time conversion kit for the NP203 and locking hubs on the front.
The part time kits are fairly easy to install and will give you a real 2 Hi position as well as a 2 Lo position.
The NP203 is not a bad transfer case, it's really heavy duty and as a full time transfer case it will perform very well. Problem arise, as so many people prefer a part time transfer case. When converted, the NP203 is not operating as it was designed. When operating as a full time case, the internal pump would move oil all over the t-case and keep it well lubricated.
After a conversion to part time operation the NP203 will operate as a part time case, but it needs to be operated routinely in 4wd with the hubs locked to ensure the t-case gets properly lubricated. The lubricant should always be motor oil (e.g. 10W-40) and not gear oil (e.g. 85W-90).
