Author Topic: lowering  (Read 6172 times)
Offline jhonijim
lowering
« on: April 29, 2004, 01:37:00 pm »
can i cut the coil spring to lower mw 2wd 81 i was reading that people do it to honda crx's to lower them and was jus wondering i dont care bout the ride it cant get worse than it is
might as well have the axle and arms welded in place
Offline RSBAD454
Re: lowering
« Reply #1 on: April 29, 2004, 02:16:00 pm »
this is what mine use to look like with one coil cut in front and 3" Bell Tech dropped spindles. The rear is a Bell Tech flip kit and some leafs removed.
Toys are my game
http://
Offline jhonijim
Re: lowering
« Reply #2 on: July 15, 2004, 03:45:00 pm »
how much drop do you get by cutting one coil also what would happen if i slowly heated the stock coil while under cotroled presure as to shoten it im looking to get 4 inches out of my front end with out speneding any money or at least little as possible and as i said be for the thing rides like @#$% with stock suspenson i want to get the weight closer to the ground for less roll around corners and with my new rims i dont have much to spend and i still need to buy paint
