Author Topic: what trans and transfer do i have ????  (Read 6253 times)
Offline tmaxxman1980
« on: April 30, 2012, 04:00:28 pm »
what trans and transfer do i have ???? here are the numbers from the trans
and this one is on the back of the transfer case
sorry to be a pain in the ass lol just would like to know
Offline DustyRusty
Re: what trans and transfer do i have ????
« Reply #1 on: April 30, 2012, 06:20:45 pm »
Hard to tell.  Appears to be an iron t-case.  Your third photo:  Is there another plug on the back similar to the one shown?  If so, it is likely a NP 205 T-case.  If not, it may be a NP 203.  Maybe post a couple more but not so close up.
Customized by rust.
« Reply #2 on: April 30, 2012, 08:07:11 pm »
     1.  First off is it a manual trans or auto trans ?
     2.  Take a pic of the pan of the trans and we can tell you, and take a pic of the whole back of the transfer case so we can see it.
     3. What does your gear shifter for the transfer case have on it for gears ?
« Reply #3 on: April 30, 2012, 08:20:15 pm »
that plug is on the back of the t case  will post more pics soon
Offline Jason S
« Reply #4 on: April 30, 2012, 08:24:41 pm »
From these and other photos you've posted, it looks to be a SM465 transmission with a NP205 transfer case.
« Reply #5 on: April 30, 2012, 08:27:19 pm »
it is a  manual trans 4 speed and here are some more pics
« Reply #6 on: April 30, 2012, 08:30:17 pm »
     The pics did not come through.  But a SM465 trans is easy to spot, it has 2 side pto ports on the trans that are covered with plates and bolts.  The gear pattern is in a H and reverse is to the right and down.  1st being granny low (you barely will move even with your foot in the gas pedal).
     I am pretty sure you have a 205 transfer case.
« Reply #7 on: April 30, 2012, 08:34:59 pm »
bottom  of the trans
side of trany and t case
back of t case
« Reply #8 on: April 30, 2012, 08:37:26 pm »
     SM465 and 205.
« Reply #9 on: April 30, 2012, 08:40:28 pm »
     SM465 and 205.
thanks  and is it a good set up ???
« Reply #10 on: April 30, 2012, 08:41:43 pm »
    Very stout setup.
