Author Topic: NP205 Rear Seal  (Read 11030 times)
Offline drtbikkid
NP205 Rear Seal
« on: May 03, 2012, 10:19:52 am »
how involved in replacing the rear seal (output shaft) in an NP205? im afraid when i get the housing off a whole mess of stuff might fall out that im not expecting.
any help is appreciated.
__________________________________________
Tire Design Engineer: Toyo Tire North America
1978 K10: 8" lift, Granny 4 speed. 84 Model 305.
"When the only tool you have is a hammer... everything looks like a nail."
Re: NP205 Rear Seal
« Reply #1 on: May 03, 2012, 11:02:07 pm »
What housing?
Remove the drive shaft, then the yoke, pop the seal out.
Use a deep socket or nicely install the new one with a brass punch, put the cleaned up yoke back on with a some blue locktight, stake the nut with a small chisel, put the shaft back in.
Offline codyC10kid
Re: NP205 Rear Seal
« Reply #2 on: May 03, 2012, 11:04:27 pm »
What housing?
thanks im gunna go do mine in a couple days,When i did my Front axel pinion seal,i used a SMALL amout of blue RTV around the seal
Re: NP205 Rear Seal
« Reply #3 on: May 06, 2012, 08:56:01 am »
You shouldn't need any silicone for a seal.
When you do use silicone it should be the good stuff, not the blue crap!
