Author Topic: Wrong Evaporator core?  (Read 5091 times)
Offline Harmon
« on: May 05, 2012, 09:46:00 pm »
Replacing my Evaporator core and the two metal hoses coming off it do not match the one that came out....anyone have that issue or know what I could do to make it work?  DIEING FOR AC IN TEXAS
Re: Wrong Evaporator core?
« Reply #1 on: May 06, 2012, 03:44:08 am »
77-87 should all be the same core. one elbow should be almost strait while the top one should have a 45 degree angle on it. pre 77 should have more of a 90 degree bend on top
« Reply #2 on: May 06, 2012, 10:17:32 pm »
     As Irish pointed out, we also need info on the truck you are working on in order to be able to help.
Offline Skunksmash
« Reply #3 on: May 07, 2012, 01:39:00 pm »
If you got it at one of the big name auto parts stores and you didn't take the old part with you to verify, then you likely got the wrong part.
