Author Topic: 1977 GMC K10  (Read 25746 times)
Offline wavedv8er
1977 GMC K10
« on: May 07, 2012, 10:07:24 am »
My first truck, big plans little buy little.... gonna start buy undercoating and painting the frame for rust protection then some flowmasters!
"The ground is my ocean, i am a shark and most people can't swim"
Re: 1977 GMC K10
« Reply #1 on: May 08, 2012, 09:02:55 pm »
      That is a good start on a restoration, are you going to be removing anything to do the frame or while truck is still on the frame ?
Offline wavedv8er
Re: 1977 GMC K10
« Reply #2 on: May 09, 2012, 12:43:30 am »
I would like to take the bed off, but am not sure how tough this will be? Any idea where i can get some info on taking bed off?
Offline BigHemi353
  • Diesel Enthusiast
Re: 1977 GMC K10
« Reply #3 on: May 09, 2012, 01:21:49 am »
Doubt you need much info to take the bed off. Think there are 6 bolts on a shortbed. Mine all needed to be torched off due to rust but you may get lucky. Try an impact from the underneath side, remove tail lights and wiring harness, and then take screws out of the gas hole door. get 4 guys to lift up on it and take it off. Good luck, looks like an awesome project!
Offline slammed79
  • Thou shalt not drive stock
Re: 1977 GMC K10
« Reply #4 on: May 09, 2012, 10:00:30 am »
Might just be me, but it looks like you should do cab mounts first, it'll help with the ride, and square up your body lines.
Praise the lowered
Offline 454Man
  • Why Race?
Re: 1977 GMC K10
« Reply #5 on: May 09, 2012, 10:28:51 am »
Nice truck
Offline wavedv8er
Re: 1977 GMC K10
« Reply #6 on: May 09, 2012, 01:40:26 pm »
Cab mounts? ill have to look into that... the driver side is lined up perfect while the bed on the pass side is about an inch higher than the cab, and im not sure why? i thought the bed was off a little, but im new to the truck world? im open to any help i can get!!
Offline Jason S
Re: 1977 GMC K10
« Reply #7 on: May 09, 2012, 04:23:33 pm »
Ditto on checking the cab mounts.
Re: 1977 GMC K10
« Reply #8 on: May 09, 2012, 07:03:53 pm »
     It could be just the way he has the truck parked in the pic.  You need to check the body lines on a flat level surface to see if they line up.
Offline wavedv8er
Re: 1977 GMC K10
« Reply #9 on: May 17, 2012, 10:15:28 pm »
Well took the bed off today, my first step towards my dream truck!! Had some help but wasnt to bad. powerwashed and wirebrushed everything, truck came from arizona so for a 34 year old truck not to much rust i dont think! Going to Paint the frame with Bill Hircsch Miracle paint to protect it and then undercoat the bed with a 3m undercoat spray. Also ordered new cab mounts because they were smashed like pancakes hopefully thats why the cab and bed werent lined up. Im open to any suggestions from the more experienced guys, remember my first truck! Ill update pics as i go.... Jay    PS thanks for the cab mount suggs think that might solve it.. keep ya posted
« Last Edit: May 17, 2012, 10:17:57 pm by wavedv8er »
Offline slammed79
Re: 1977 GMC K10
« Reply #10 on: May 18, 2012, 09:25:05 am »
Lookin good man! Gotta love desert trucks
Praise the lowered
Re: 1977 GMC K10
« Reply #11 on: May 18, 2012, 04:39:07 pm »
     When you re-install the bed use the cab to center it up and make sure it lines up, then you can use the bed to line up the cab if you take it off to do that part of the frame.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: 1977 GMC K10
« Reply #12 on: May 18, 2012, 09:08:46 pm »
I like it man!   Don't change the height or tire size.  looks perfect in the first 2 pics.  Good luck and most of all have fun with it!
Offline wavedv8er
Re: 1977 GMC K10
« Reply #13 on: May 18, 2012, 09:44:23 pm »
Thanks, i was gonna try ang go bigger but it rides so good the way it is i think ill just leave it. Started to paint the frame today heres a couple pics.
Re: 1977 GMC K10
« Reply #14 on: May 19, 2012, 11:24:05 am »
     Nice shiny new black, gotta love it when it is parked there all pretty, that is until you start driving it and it gets dirty and covers up the shiny paint.   :'(
