Author Topic: 383 stroker!!!!  (Read 7093 times)
Offline 87 V20
383 stroker!!!!
« on: May 07, 2012, 03:32:00 pm »
I'm gonna build my 350 to a 383...I wanna keep tbi so is there somekinda tbi set up that will be big enough for it...ive heard of it but cant find it.
Re: 383 stroker!!!!
« Reply #1 on: May 07, 2012, 09:42:55 pm »
Not exactly sure what you have in mind, so here are three possibilities to consider (no recommendations are implied):
http://www.summitracing.com/parts/FST-30227-KIT/
http://www.summitracing.com/search/Make/CHEVROLET/Engine-Size/5-7L-350/Brand/Motorvation/?keyword=TBI+fuel+system+kit
http://www.summitracing.com/parts/HLY-550-411/
But if you are going to go to this kind of trouble and expense, why not convert to sequential port injection?   ???
Either way, there are always hidden costs (usually a lot), problems (usually a lot), fabrication challenges, lots of decisions, and delays.  Do you need to pass any emissions requirement now, or in the foreseeable future?
Re: 383 stroker!!!!
« Reply #2 on: May 21, 2012, 01:52:11 pm »
Keep the TBI as in the factory setup including the ECM?  You have to be particular on the cam selection and you will have to have a chip burned.
Offline Korndiggity
Re: 383 stroker!!!!
« Reply #3 on: June 14, 2012, 06:10:56 pm »
Just a quick question...what is the driving force behind the 383? Why not just use a 400? I've heard the saying, "there is no replacement for displacement". I have a 400 sitting on my stand, and I am looking fwd to throwing that baby in my 84 4x4.
Its cool that you wanna stroke that motor, but either way you are looking at balance and clearance. Why not just keep the large 4.125 bores of the 400? Good luck man!
Wes
84 Chevy Scottsdale SWB 4x4; 4" suspension lift.
Re: 383 stroker!!!!
« Reply #4 on: June 15, 2012, 05:00:06 pm »
He would have to get a 400 Block to make a 400...
Offline Korndiggity
383 stroker!!!!
« Reply #5 on: June 18, 2012, 01:23:22 pm »
Good call Capt-but with everything he is going to spend on stroking his tree-fitty, just get a 400 block and have more cubes, same stroke-
