Author Topic: Ls motor  (Read 8350 times)
Offline 1979C20
  • Kyle Taulton.
Ls motor
« on: May 11, 2012, 02:16:15 pm »
Im looking into an ls swap, but I have a quick question. I want to keep my SM465, so what would I have to do for the VSS? I was told I have to have a VSS for the computer, but I have a manual cable speedo.
Offline slammed79
  • Thou shalt not drive stock
Re: Ls motor
« Reply #1 on: May 11, 2012, 04:27:16 pm »
I think there is some kind of adaptor out there. Try google.
Praise the lowered
Offline Psycho71
Re: Ls motor
« Reply #2 on: May 15, 2012, 12:23:34 pm »
I have been told by several people that using an auto trans like a 350 or 400 behind an LS engine requires only a spacer for the flywheel. Not sure about the standard trannies though. Try here- http://67-72chevytrucks.com/vboard/forumdisplay.php?f=206
Offline DnStClr
Re: Ls motor
« Reply #3 on: May 19, 2012, 11:46:38 am »
Have you done any searching on the LS1 Truck site? It might be your best reference.
http://www.ls1truck.com/
Don
87 Chevy Silverado
Re: Ls motor
« Reply #4 on: May 21, 2012, 11:56:29 am »
Are you changing out all of your gauges to the electronic speedo? you can use a VSS sender.
Offline 1979C20
  • Kyle Taulton.
Re: Ls motor
« Reply #5 on: May 22, 2012, 11:04:06 am »
I guess I could put an electric speedo on it. I dont even use my speedo aince its off by like 15mph, I use my gps for speed. So, does the vss sender replace the cable sender? Is it gear driven from in the tailhousing or is it cable driven from where the speedo.cable screws in?
Re: Ls motor
« Reply #6 on: May 24, 2012, 12:56:25 pm »
Depends on which way you go.  Most swap to the 89-91 speedo.
