Author Topic: updating fuse box  (Read 9846 times)
Offline baddogg79
updating fuse box
« on: May 14, 2012, 05:52:10 pm »
On my 73 i have the wonderful glass fuses. I'm stripping my 89 blazer and though about installing the blazer fuse box into my 73. The blazer is TBI so i know there is wiring i wont need. My question is, would it be easier to swap the fuse box/harness out of the blazer, or just buy a new fusebox/harness and wire it all up from scratch?
Re: updating fuse box
« Reply #1 on: May 15, 2012, 06:35:32 am »
     Anything is possible.  But you are talking about a lot of work and if you get wires messed up or crossed it could become frustrating very fast.  Have you checked into updating the 73 with a after market one before you go and get one from a 89 ?
Offline baddogg79
« Reply #2 on: May 15, 2012, 03:40:25 pm »
Ya i was seeing what would be easier. I didnt want to spend an arm and leg for a aftermarket harness, but if it will save me time (and possible money) in the long run i guess that the better option
Offline HAULIN IT
« Reply #3 on: May 15, 2012, 09:43:16 pm »
What do you have against glass fuses? They don't cook or clean, nag too much, have gained a few pounds over the years? ::)
Offline slammed79
  • Thou shalt not drive stock
« Reply #4 on: May 16, 2012, 12:11:16 am »
My 74 has glass fuses it doesn't bother me. I just keep an assortment in the glove box since most gas stations out here don't have them anymore.
Unless your harness is butchered beyond repair, I'd just leave it alone.
Praise the lowered
« Reply #5 on: May 16, 2012, 06:10:40 am »
     I personally do the same for my 74, I think it is easier to see (for me) when a glass fuse has blown than the mini ones.
« Reply #6 on: May 21, 2012, 12:35:56 pm »
On the LS conversion I am doing I am pulling out all of the TBI harness along with other wires I don't need.  It is time consuming to remove all of it, but you don't have to remove it.  You can just leave it there.  I don't want it in there so I am pulling it all.  Keep in mind the Blazer will be fine until you start heading to the rear where you will need more length.
