Author Topic: Center Band Molding Position  (Read 12828 times)
Offline Edahall
« on: May 15, 2012, 02:17:18 pm »
I'm getting ready to paint and was wondering if anyone has the correct measurements to locate where the rubber molding is suppose to go on the side of the vehicle.  The factory job was different on each side.  By the way, this is for 89-91 Suburbans.
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Re: Center Band Molding Position
« Reply #1 on: May 21, 2012, 12:43:24 pm »
Ed,
Ere you talking about the bodyline molding...
Offline Edahall
« Reply #2 on: May 21, 2012, 10:14:54 pm »
Ed,
Yes,
I was wondering if there was any standard for this?
-3.73 gears
-2" Lift
« Reply #3 on: May 21, 2012, 11:38:06 pm »
Yes, it would match the centerline of the rear piece that bolts to the bed corner and basically the bottom of the front turn signal.
Here is a visual...
Offline Edahall
« Reply #4 on: May 22, 2012, 01:43:38 pm »
Thanks,
I got her all painted up.
-3.73 gears
-2" Lift
Offline fitz
« Reply #5 on: May 22, 2012, 03:27:28 pm »
Looks great. Did you paint it yourself?
Offline Edahall
« Reply #6 on: May 22, 2012, 10:23:17 pm »
Yes I painted it myself under that metal shed.  I also stripped it all down to bare metal.
-3.73 gears
-2" Lift
« Reply #7 on: May 24, 2012, 12:51:28 pm »
Nice work!  Looks good.
