Author Topic: TH400 swap  (Read 3579 times)
Offline klaussk
TH400 swap
« on: May 18, 2012, 08:41:04 am »
I have a 78 TH400 out of a 2 wheel drive RV. It appears to have been rebuilt recently and it came with the rebuilt 400 I purchased. I am wondering if it is possible to install this transmission in my 85 K10. its a 4 wheel drive stepside shortbed and originaly had a  700R4 in it . Can I take the tailhousing  off the TH400 and install the transfer case. Thank you
Go ahead hit it with a hammer. Theres only one level of broke.
Offline slammed79
  • Thou shalt not drive stock
Re: TH400 swap
« Reply #1 on: May 18, 2012, 09:33:40 am »
I could be wrong, but that kinda conversion is more trouble than its worth. You'd probably do better to sell both transmissions and buy a 4x4 th400.
Praise the lowered
Offline klaussk
Re: TH400 swap
« Reply #2 on: May 18, 2012, 02:41:03 pm »
How strong do you think a TH400 is.
Offline slammed79
Re: TH400 swap
« Reply #3 on: May 18, 2012, 05:03:54 pm »
I've only ever had one go out on me. Tough trans. If the truck is a dd I'd keep the 700r4, a little nicer to the wallet.
Praise the lowered
Re: TH400 swap
« Reply #4 on: May 21, 2012, 12:07:40 pm »
The output shaft length is different on the 4x4 vs 4x2, to swap it you have to take it apart completely.
Offline klaussk
Re: TH400 swap
« Reply #5 on: May 22, 2012, 01:04:54 pm »
I think it would be easier to just find a rebuilt tranny or rebuild mine. I'm not to sure about my ability to rebuild a  transmission in the time I will have to rebuild it.
