Author Topic: How does one lift a 4L80E up into place?  (Read 6470 times)
Offline scorpion
« on: May 21, 2012, 08:13:54 pm »
I had a lift when I owned a business years ago.  Was big and strong.  Had hired help then too.  When you combine all of that, its fairly easy to install a tranny of any size.   :o
Now years later, I'm a home garage kind of guy and my '74 Chevy needs a tranny.  No lift, no neighbors who can or should attempt to lift a 4L80 while laying on their back, and my shoulder and back can't handle much these days.  Lifting it out of the truck was interesting.  I'm fairly resourceful and have looked around at scissor tables and tranny jacks but the lift height seems to be too short.  All tranny jacks made for lifts are too tall or cost prohibitive.  I could easily build a nice scissor table that suits my needs but, more often than not, I over build which ends up taking far longer than it should and, though it would be sweet to have one, I don't really need one taking up space.  Ive considered making an adapter gizmo to turn my cherry picker into a lift but envision an epic fail.  I could jack up the truck, get the tranny under it, remove the wheels and lower it down over the tranny on any of the fore mentioned lifting/supporting devices...which is about the point where my wife says "why do you like that old truck again?".  ::)
I've considered paying someone local but, if you're like me, you don't like (trust) someone to touch your junk.  Another issue is that my tranny swap isnt exactly simple.  SM465 to 4l80e.  I have *most* parts but, knowing my projects, something will need some thinking (exhaust, driveshaft, crossmember, etc)...which either the corner shop charges and arm and a leg for (I used to), or they aren't capable of doing.  I can do it all, no joke, but can't get the tranny in.  I find it funny given what I used to do on a daily basis.
Any ideas?  Cheap one-time solutions, brainstorms, or epiphanies would be great.  Don't need the one ton and/or tranny crushing my butt so hold back the plans that involve stacking 2 cinder blocks and four 2x's on a radio flyer...I might just have already tried it but I won't tell.
TIA
Offline scorpion
Re: How does one lift a 4L80E up into place?
« Reply #2 on: May 21, 2012, 08:24:07 pm »
Lift height on that jack is 24".  The bottom of the frame rails is 30" I think.  I have to go up into the truck the height of the tranny above the bottom of the frame rail...that's a difference of more than a foot.  So how do you use one of these lifts to accomplish that?  Am I missing something obvious?
« Last Edit: May 21, 2012, 08:27:03 pm by scorpion »
« Reply #3 on: May 21, 2012, 11:32:20 pm »
Are you working on a 4x4 or a 1 Ton?   How tall are the tires on it?
I guess if that is a viable option and you can let the air out of some tires it would work...
Offline scorpion
« Reply #4 on: May 23, 2012, 07:03:38 am »
It has a 6" lift on it.   Ya know, I guess I was tired when I pulled a tape on it the other night.  I don't know how I did it but I read 30" to the frame rails when it actually was 26.  After your post, and some rest, I went back outside second guessing myself - people swap trannys all the time themselves with trucks taller than mine...anyway, I had the same thought as you.  I went to harbor freight, let the air out of the tires, and voila, drivetrain out.  For those of you skeptical about the quality of the Harbor freight unit, it doesn't seem like junk.  It's much more substantial than it looks in the picture and worked very well.  I'm glad I got it and plan to use it on the fuel tank swap coming up soon.
I only got a few hours to work on it last night.  I'm totally excited to get back at it and try out the F.A.S.T. stand alone controller.  It's been sitting on my workbench for months haunting me.
Thanks for your help.
« Reply #5 on: May 24, 2012, 12:50:30 pm »
great! thanks for the feedback.
Offline roadrage41
« Reply #6 on: June 11, 2012, 08:46:36 pm »
my craftsman motorcycle jack has lifted many more transmissions than it has motorcycles.
Offline scorpion
« Reply #7 on: June 15, 2012, 05:07:54 am »
I looked at a few motorcycle lifts but one of them lifted as high as I needed.  Fortunately the HF unit worked out.
