Author Topic: Swap NP203 too NP205 ????  (Read 11024 times)
Offline wavedv8er
« on: May 23, 2012, 02:05:29 pm »
I have a 203 with the conversion kit in it, behind a th-350. I was wondering if i can buy a NP-205 and have my transmission shop swap them out?, or would there have to be a lot of mods made? Unfortunatley there is not a lot of 4x4 shops where i live who are 2 familiar with these transfer cases and such. I have manual locking hubs in the front. Or would i have to buy a new tranny and transfer case at the same time? Please help?? thanks Jay
"The ground is my ocean, i am a shark and most people can't swim"
Offline DustyRusty
Re: Swap NP203 too NP205 ????
« Reply #1 on: May 23, 2012, 04:05:33 pm »
This won't be a direct swap because the input shaft spline counts are different for the two t-cases.  However, I think there are a few members that have done this same swap.  They will likely chime in with the details.
Customized by rust.
Offline Cabcorner
« Reply #2 on: May 26, 2012, 06:38:34 am »
               If you find a 205 off a th350 with the shifter, adapter and coupler sleeve it will bolt right up . These were common on the 1980 chevy model year . You will have to adapt your drive shafts or get ones from a parts truck because the lengths are different .  You may also need a different crossmember depending on which one you have. Do your homework because a lot of parts are incompatible .
