Author Topic: Where to find a shift tube lever for a 1974?  (Read 5908 times)
Offline scorpion
« on: May 23, 2012, 10:00:07 pm »
After inspecting the column I have, it occurred that I could salvage it if I could find a shift tube lever to replace the one the previous owner cut off.  I've searched and the places I've found say their discontinued.  Any one know where I could find this part?  A complete shift tube would work too.
Or does anyone know which years levers or tubes interchange with a 1974 k20?
TIA
« Last Edit: May 23, 2012, 10:08:01 pm by scorpion »
Offline slammed79
  • Thou shalt not drive stock
Re: Where to find a shift tube lever for a 1974?
« Reply #1 on: May 24, 2012, 12:32:00 am »
Hit the junkyard or craigslist. You should be fine up to 77 I think.
Praise the lowered
« Reply #2 on: May 24, 2012, 08:43:31 pm »
     Shift tube lever ?  Are you talking about the floor shifter or column shifter ?
Offline scorpion
« Reply #3 on: May 24, 2012, 10:28:54 pm »
The shift tube lever is the thing that the linkage attaches to at the bottom of the steering column (under the hood).  It's basically a steel bracket that rotates at the other end of the steering column when you move the shift handle.
« Last Edit: May 25, 2012, 08:14:05 pm by scorpion »
