Author Topic: Picked up a complete topend and fuel injection setup from a 91 olds  (Read 8162 times)
Offline travisr1988
It was from a 91 olds custom cruiser...got the heads, intake, throttle body with injectors wiring harness and ecm off of a friend for free because the car was totalled. Now i just gotta clean it all up, adapt the wiring to my truck and get it all put on...this is gonna be awesome!
1979 Chevrolet Silverado C20 rclb cammed 355/th400/4.10 - sold
1977 Chevrolet Custom Deluxe c10 rcsb stepside 355/th350/3.42
Vortec heads lunati cam edelbrock intake headers
     So I assume you checked and it will fit right ?
Offline slammed79
  • Thou shalt not drive stock
I believe 91 was when oldsmobile switched to the chevy engine, so he should be fine.
Praise the lowered
Offline travisr1988
Yes it was a chevy 305. I'm just trying to get better mileage out of this truck b/c 8mpg is not cutting it. I'm seriously ready to trade it for a s10 b/c of how much gas it drinks
Offline slammed79
If you're only getting 8 out of a small block, something is very wrong, either mechanically or with your right foot.
Assuming you're reletively sweet to the gas pedal, you may want to check your timing, tune up, carb adjustment, etc. What carb is on the truck? You don't need much more than a 500 cfm carb on a 350.
Praise the lowered
     x2.  my 74 right now with #1 cylinder sucking oil gets 11 - 12 and it is a 4x4.
Offline travisr1988
My right foot is gentle on this truck, tge carb is a rebuilt quad my dad
rebuilt, has been adjusted. We suspect a bad timing chain so we're replacing that on saturday, it does burn oil and the ••oil pressure drops sometimes at idle and it seems to drink more gas when that happens, it has worn out 235/85r16s on it and a 160°tstat
Offline Jason S
Nice score on the fuel injection.
Did you get the chain replaced and did it help?
Offline travisr1988
Replaced the chain, found the distributor advance wieghts were siezed and the distributor was burnt up, my dad says the truck shouldn't have been able to run at all. But we fixed it and it's now getting 12-13mpg. next is tires and then we can try getting that F.I. Setup on it.
