Author Topic: another coil spring question  (Read 5229 times)
Offline coolcuz820
« on: November 19, 2004, 02:49:00 pm »
I have a 79' C20 that has a heavy duty suspension. I just recently removed 5 of the 9 leaf springs in the rear. Much smoother ride in the rear. My truck is lower in the back by a little bit. If I put the 1/2 ton coils in the front, will this lower a the front a bit? I know I will also get an even more smoother ride. I want it to be about an even height, or even a liitle rake is okay. thanx:D
Offline roundedline
Re: another coil spring question
« Reply #1 on: November 22, 2004, 02:14:00 pm »
yes it will drop it some.  Keep in mind the springs are one of the major things that made it a C20.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline coolcuz820
« Reply #2 on: November 22, 2004, 06:32:00 pm »
thanx roundedline
