Author Topic: Frame swap  (Read 6075 times)
Offline Ace1984
Frame swap
« on: November 23, 2004, 01:14:00 pm »
I have a 1986 1/2 ton frame and i as wondering if i could put a 73' to 80' body on to that frame and if not which bodies will fit the frame?
Offline roundedline
Re: Frame swap
« Reply #1 on: November 23, 2004, 12:41:00 pm »
Yes you can.  You will need to use the body mounts for the year of the frame (81-87).  If you plan to keep the '86 front end, the cab will need modification for it to work.
You might want to check with the local DMV though since the cab has the VIN on it.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
