Author Topic: Lockers  (Read 4098 times)
Offline Farm boy
Lockers
« on: June 10, 2012, 01:03:09 pm »
I like any good teenager would like the better traction of a locking dif; but like most teenagers can't afford them. So to the point: i was wondering if any of you guys know how well these work http://www.justdifferentials.com/index.php?main_page=product_info&cPath=24_45_279&products_id=3762 both on the road and off.
K10-350 w/Holley 4bl, 350th, 33-12.5-15s, blue)-parting out
K10-350 w/Holly 4bl, bad th350 swapping to sm465, 33-12.5-15s, CAMO!
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: Lockers
« Reply #1 on: June 10, 2012, 08:46:28 pm »
Aaaah yes the lock right locker used and installed many. Good entry level diff upgrade must currently hAve open diff so check that your current diff is not a limited slip also they will grenade with an over aggressive right foot, however a little Common sense and a lock right is definitely a great choice
Offline Farm boy
Re: Lockers
« Reply #2 on: June 10, 2012, 10:52:19 pm »
Well right foot "twitching" will be kept to a minimum do to i can't afford to keep 33in mts on there if they are always mysteriously smoking ;) It will mostly be for off road use.
Offline pholliday1
Re: Lockers
« Reply #3 on: June 11, 2012, 07:25:21 am »
If you put a lockright front and rear you will be amazed and think you have a whole new truck sounds like your on the right track!
Offline Farm boy
Re: Lockers
« Reply #4 on: June 11, 2012, 10:17:27 am »
All right thanks. I had asked because I know auto locking difs tend to jerk and what not on the road, and since this will be my only vehicle i don't wont to be wearing stuff out when I drive on the road.
Re: Lockers
« Reply #5 on: June 11, 2012, 11:26:59 am »
Summit is running a sale:
http://www.summitracing.com/parts/PWT-1910-LR/
You can download installation instructions from here, too.
You'll experience some loud snapping/popping/banging from the unit on turns for awhile, but it will 'graudually' diminish over 12k - 15k miles.
Re: Lockers
« Reply #6 on: June 11, 2012, 12:12:37 pm »
     As philliday1 stated, a very good entry level locker, used many in jeeps before I upgraded for air lockers.  Surprisingly they work very well off road also, especially in mud.
Offline Farm boy
Re: Lockers
« Reply #7 on: June 11, 2012, 12:43:23 pm »
Well I probably won't be making use of that sale since i probably won't be able to buy them till fall at the soonest. I was more wondering weather to save for that or a lift kit.
