flexplate problems
Topic: flexplate problems (Read 7802 times)
rusty but trusty
flexplate problems
June 15, 2012, 06:46:52 pm »
is there a easy fix for a flexplate that's not letting the starter work right could i just file it or how do i replace it with minimum tools
all help appreciated
87 GMC V1500 305 700R4 NP208 and 10 bolts front and rear
Jason S
Re: flexplate problems
June 15, 2012, 06:57:47 pm »
Are you sure you have a flexplate problem and not a starter that needs shims?
If your sure it's the flexplate, you'd remove the transmission and torque converter and then the old flexplate and swap on the new flexplate.
rusty but trusty
June 17, 2012, 08:26:43 pm »
its defiantly the flexplate i put in a junkyard starter and the part that sticks into the torque converter shield shattered one day and i didn't think the bits would bother anything but i have learned i was very wrong
Sartobuilt
June 18, 2012, 08:55:33 am »
I think we need a picture of this. For better clarification.
rusty but trusty
June 18, 2012, 01:40:19 pm »
iv never removed a engine much less a tranny any tips and tricks and do i have to remove the t case separate or with the tranny
Blazin
Blazin new trails!
June 18, 2012, 04:07:16 pm »
if you don't have a transmission jack I would say it would be easier to remove the t case, and trans separately. A basic set of hand tools, wrenches, and sockets with some occasional pliers, and a screw driver or two will remove them.
rusty but trusty
June 20, 2012, 04:33:00 pm »
here is the damage
Blazin
Blazin new trails!
June 20, 2012, 11:24:05 pm »
Looks like the starter was not shimmed correctly, to close to the flex plate.
codyC10kid
June 20, 2012, 11:27:02 pm »
My Guss it is your starter not shimed right....and yeah that fly wheel needs replacing....A list of what i used to pull my TC and tranny out was Catch Pans....gunna need them to drain the fluid.Basic tool,a tranny jack or a floor jack with a tranny adapter....And dont forget to use thread locker on the flex-plate bolts,i might of forgot some stuff,I did this once like 1 year ago, lol good luck
454Man
Why Race?
June 21, 2012, 12:38:53 am »
Hey just wondering if the starter ever mad any noises after you installed it? Just seems like it would have been making some weird sounds.
rusty but trusty
June 21, 2012, 08:45:35 am »
could i weld some more metal where the teeth are bad and file it back to the way it should be for now until i can get a tranny jack
rusty but trusty
June 23, 2012, 09:08:58 pm »
the damage was caused by pieces of starter that fell into TC shield and broke some teeth
flexplate problems
