Author Topic: Inline pump  (Read 3726 times)
Offline RicoTizzio
Inline pump
« on: June 16, 2012, 02:43:58 pm »
I have a 84 dual tank  short bed it a project. I have installed a project 89 5.7 n 700 tranny. My problem is the space between my fuel line and tank selector. Will i have to cut the metal line in order to use both tanks. Thanks guys
Re: Inline pump
« Reply #1 on: June 17, 2012, 04:39:00 pm »
     I don't really understand the question.
  By the way welcome to the site, and you should make a post under "general information" under "welcome" tab so everyone can say hello.
Offline bake315
Re: Inline pump
« Reply #2 on: June 18, 2012, 04:32:03 pm »
I'm afraid I don't understand your question either.  I'll take a stab, though.  Does the hard line go all the way to the switching valve?  If it does, then I'd think that you will have to open a section of that line to insert the pump.  If we had a little more info on why you're adding this pump it would really help us to help you.
« Last Edit: June 18, 2012, 04:36:25 pm by bake315 »
• '73 Cheyenne Super C20 454/400 http://forum.73-87chevytrucks.com/smforum/index.php?topic=7672.0
• ’79 Scottsdale K10 350/NP208/SM465 “Oscar” http://forum.73-87chevytrucks.com/smforum/index.php?topic=37885.0
Offline RicoTizzio
Re: Inline pump
« Reply #3 on: June 22, 2012, 01:20:49 am »
I was installing the pump because i put the 87-95 block n my truck with the brackets. Didn't know if the mechanical fp was going to fit. I've got the pump installed now.
