Author Topic: trans shift  (Read 2948 times)
Offline 77 cc lb
trans shift
« on: June 16, 2012, 03:37:16 pm »
I recently bought an 88 R20 suburban with a 454/th400 trans. The trans. was rebuilt a couple years ago. It doesn't want to go past 2nd gear, was wondering if the modulator could be bad or something else. I added a qt of fluid because it was low and still no difference. Any ideas would be appreciated.
87 Chevy crewcab shortbed soon to have a 454/400
Offline slammed79
  • Thou shalt not drive stock
Re: trans shift
« Reply #1 on: June 16, 2012, 07:39:13 pm »
Can you manually get it in to third? If not it could be gone.
Praise the lowered
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: trans shift
« Reply #2 on: June 16, 2012, 11:36:02 pm »
you sure your vacuum line (to modulator) is still hooked up to the intake vacuum behind the TBI?  I guess the '88 TBI th400's are that way.
Passing gear stuck in passing mode?
Offline 77 cc lb
Re: trans shift
« Reply #3 on: June 18, 2012, 04:03:30 pm »
Thanks Lt.DeL and slammed I will check those out. I am going to try and get a hold of prev. owner to see who did the repair and a couple other things. Thanks guys
