Author Topic: Engine guys  (Read 4346 times)
Offline slamin81
Engine guys
« on: June 16, 2012, 05:53:42 pm »
what size  is this engine im thinking 305 not 100% tho. it in a 84 GMC SB
Offline DWFarmboy
Re: Engine guys
« Reply #1 on: June 16, 2012, 06:02:10 pm »
Dipstick on the passenger side usually is a give away to a 305 on older models.
Look behind the head on the driver side for the casting number on the block. Should end with 010 if its a 350.
Offline onelow84
Re: Engine guys
« Reply #2 on: June 17, 2012, 10:55:42 am »
pass side dipstick just indicates that it is 81 and newer, get the numbers behind the drivers side head if you can...
Offline DWFarmboy
Re: Engine guys
« Reply #3 on: June 17, 2012, 12:56:12 pm »
Ok well from late 75 to 80 you could tell cause the the dipstick was on the passenger side.  ;D
Re: Engine guys
« Reply #4 on: June 17, 2012, 05:16:38 pm »
     You can not tell 100% for sure from just looking at a 305 or a 350.  You have to get the casting number from below the drivers side head on the block and run it to see what engine family it is from.
Offline 1980c10
Re: Engine guys
« Reply #5 on: June 18, 2012, 03:00:10 pm »
Do this to be sure, too many variables any other way. Someone has done a few things on that engine as well. I see headers, carb, intake. it would be worthwhile to know what heads you have as well. For that look for a number as well under the valve covers or look for the pattern in the end of the head.
Re: Engine guys
« Reply #6 on: June 18, 2012, 04:02:02 pm »
The numbers on the blocks deck just ahead of the right side head under the alternator will tell you allot more.
