Author Topic: If you had $500 to spend on your truck...  (Read 8493 times)
Offline Shawn0331
    • My Blog
« on: June 17, 2012, 06:27:32 pm »
What would you buy if you had $500 to spend on your truck? I'm getting some back pay and my wife has agreed to let me spend $500 on my truck for whatever I want (score!).
A few things I'm wanting, but I'm open to suggestions:
  • Window seals, felts, door seals for sure
  • Window motors (they are creeping along and scary)
  • carpet?
  • dash pad?
Any suggestions?
1987 Chevy V10 Silverado SWB 5.7 on 33x12.5's
http://www.shawnseeley.com
Offline audrima
Re: If you had $500 to spend on your truck...
« Reply #1 on: June 17, 2012, 07:11:25 pm »
for $500 I would fix anything that keeps it from being inspectable, driveable. comfortable. in that order. :>
« Last Edit: June 18, 2012, 08:27:42 pm by audrima »
Offline 454Man
  • Why Race?
« Reply #2 on: June 17, 2012, 07:12:20 pm »
X2
Offline Shawn0331
    • My Blog
« Reply #3 on: June 17, 2012, 09:07:17 pm »
After I get the short found and fixed, I'm putting in the oil pressure switch and sending units, then it's all fun money. It runs like a champ.
Offline howlinwolf
« Reply #4 on: June 18, 2012, 08:30:08 am »
Tires
78 Chevy Custom Deluxe flatbed, PROPANE POWERED
Offline slammed79
  • Thou shalt not drive stock
« Reply #5 on: June 18, 2012, 09:33:26 am »
Hmm... $500? I'd get my drop springs and shocks, then get my swb frame finished up.
Praise the lowered
« Reply #6 on: June 18, 2012, 03:36:08 pm »
I would probably let the little problems with my truck go. i would spend it on my 55, or buy a new seat for the bike!!  ;D
Offline Donut
« Reply #7 on: June 18, 2012, 04:12:24 pm »
Gas.
Actually I like Blazin's thinking.   :)
500 could go toward other things. (tools? sock it aside until needed?)   For me, if 500 fell into my lap, may look into a cam change for my truck.  But, I could find other things to spend it on, unfortunately.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Offline bake315
« Reply #8 on: June 18, 2012, 04:19:19 pm »
I'd probably throw it at the machine shop work needed on my 454 rebuild.
• '73 Cheyenne Super C20 454/400 http://forum.73-87chevytrucks.com/smforum/index.php?topic=7672.0
• ’79 Scottsdale K10 350/NP208/SM465 “Oscar” http://forum.73-87chevytrucks.com/smforum/index.php?topic=37885.0
Offline wildcatjason
« Reply #9 on: June 18, 2012, 08:24:18 pm »
I had a problem with my 70 monte and an electrical short. What I did was take an amp meter tape the negative to a battery post and the positive to the battery cable. If you have a short it will show a voltage/amps whatever you have it set at. Start at the battery and and unplug everything one plug at a time leading into the cab. Once you unplug the thing shorting the voltage will drop to nil.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #10 on: June 18, 2012, 08:45:11 pm »
I'd do the first two.  they are about functionality and the last two are cosmetic.
On the other hand, if the bad dash is irritating you since it's all you see while driving, I might do that first.
I'd definately want the windows working.  its a big pain in the butt when they quit working, or worse yet get stuck DOWN.  I'd definately make the window motors #1.
