Author Topic: Quadrajet idle solenoid  (Read 26754 times)
Offline Fairlane514
« on: June 22, 2012, 10:12:11 am »
I need help finding a idle solenoid for my quadrajet. It bumps up the idle when you turn on the A/C,.................. the previous owner removed it.
Thanks!
Re: Quadrajet idle solenoid
« Reply #1 on: June 22, 2012, 10:50:01 am »
Don't know what year/model you're working on, but Napa, AutoZone, etc. sells them (e.g., here's one from AutoZone for an 84 C10, 350)...
http://www.autozone.com/autozone/parts/1984-Chevrolet-C10-1-2-ton-P-U-2WD/Idle-Stop-Solenoid/_/N-ik2xfZ9gsoj?filterByKeyWord=idle+solenoid&fromString=search
They should be commonly available.
Offline Fairlane514
« Reply #2 on: June 22, 2012, 12:14:24 pm »
Thanks, I found that one, but its not available...........not sure why they have it on their website, if its not available!
Offline Fairlane514
« Reply #4 on: June 22, 2012, 02:23:59 pm »
Thanks!  The NAPA by me actually has one in stock!
Offline Fairlane514
« Reply #5 on: June 22, 2012, 04:09:14 pm »
Well, I got the NAPA part and it looked good, but its not the right one.   Bracket is wrong and terminal is on the wrong side. I could probably make it work, but I would have to drill out some spot welds and turn the "motor" 180 degrees, and make a new bracket.
The more I mess with it, I could just add a piece of metal to the linkage so the plunger has something to push against.
« Last Edit: June 22, 2012, 04:48:36 pm by Fairlane514 »
Offline slammed79
  • Thou shalt not drive stock
« Reply #6 on: June 22, 2012, 06:02:34 pm »
Pull the numbers off your carb to make sure you've got the carb thats supposed to be on your truck. Different production years had different ways of mounting components.
Praise the lowered
Offline Fairlane514
« Reply #7 on: June 22, 2012, 07:29:53 pm »
Yes, its the correct 1984 quadrajet.   I ended up using some .060 aluminum and making a "stop" for the solenoid plunger.  It works, I just need to check my rpms at idle and see how much it kicks up when the solenoid is activated.
« Reply #8 on: June 22, 2012, 08:00:08 pm »
Glad you found one, so sorry I hadn't ventured out to the shed yet... Still a little wobbly walking on uneven ground yet...
Offline Fairlane514
« Reply #9 on: June 23, 2012, 06:40:57 pm »
Checked my rpms today.  In park idle is just under 800, when I engage the A/C and the solenoid, it bumps it up to just over 1000 rpms.
