Author Topic: gross vehicle weight  (Read 5517 times)
Offline aprice
« on: January 24, 2005, 12:38:00 am »
what are the chances of an 1980  k20 having a gvw of 12000 lbs. NOw this is stated on the sitcker in the glove box. i checked the vin to be sure it matches the cab and the title and which it does. The front springs have 4 leaves i think and the rear have 5-6 leaves for sure. the most i have seen any 3/4 ton truck is 9200 lbs and that was the truck i took the body off of for my mudder which had 9 leaves in the rear and only 2wd
Offline roundedline
Re: gross vehicle weight
« Reply #1 on: January 24, 2005, 02:14:00 pm »
A heavy Duty K20 could have 8600, but 12000 would be a K30 Crew Cab.  I guess it is possible though.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
