Author Topic: Truck will not start  (Read 7853 times)
Offline Harmon
« on: June 27, 2012, 12:11:11 pm »
Truck was running fine before I left for a week to go on vacation.  When I returned the truck would not start.  It turns over fine, but doesnt try to fire.  What would be my first step?
Offline thirsty
    • Suitor's Garage
Re: Truck will not start
« Reply #1 on: June 27, 2012, 12:34:27 pm »
Does it have a carburetor? If it were mine I would put some gas down it's throat and see if it goes.
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #2 on: June 27, 2012, 02:47:40 pm »
Check the hot wire to your distributor. I once had a cat walk around on top of the engine and unplug it.
Offline 1980c10
« Reply #3 on: June 27, 2012, 05:17:52 pm »
both of those are great advice, if neither gets you back on the road; check for spark
Offline Harmon
« Reply #4 on: June 27, 2012, 05:31:53 pm »
Thanks yall...my bad..its a 86 chevy truck....carb yes.  I will put gas inthe carb and see if it attempts to fire....Thanks.
« Reply #5 on: June 27, 2012, 09:10:40 pm »
     Just don't put too much in, or else you might have it backfire up through the carb.
Offline snibook7537
  • Vince Ziolkowski
« Reply #6 on: June 30, 2012, 02:22:22 am »
How did everything go harmon? Let us know if you got her running.
1984 Fiero se pwr windows Holley TBi, cam, 86 5spd
1987 GMC V3500 350 TBi 4spd 205 t-case
Shoulda never sold:
1976 c-10 beater 250-6 4spd no pwr steering, brakes. Recycling truck
Offline Harmon
« Reply #7 on: June 30, 2012, 09:38:18 am »
Hey yall, put some gas in carb and tried fire'in up the truck.  I got nothing.  I guess my next step is to check for spark?
What frustrates me is I replaced the distributor a last year because something like this happened before...anyways.....to check for spark i can pull one spark plug, leave wire attached and hold close to metal while starting and see if there is a spark?
Offline 454Man
  • Why Race?
« Reply #8 on: June 30, 2012, 10:01:46 am »
Yes
Offline DnStClr
« Reply #9 on: June 30, 2012, 01:54:26 pm »
Harmon, why don't you put a jumper across the ALDL terminals A to B to see if the ecm has stored any code faults? The ALDL connector is located under the left side of the dash near the steering column. A quick search on this site should get you a thread explaining how to do it. It's not difficult.
Don
87 Chevy Silverado
