Author Topic: 12 Bolt Rear End Disc Brake Conversion  (Read 19378 times)
Offline Orlando87Chevy
« on: June 28, 2012, 07:21:42 pm »
Ok I have been doing some research around the Internet for a rear disc brake conversion on my 12 bolt rear end. Is there a factory setup I can pull from another Chevy that I can pull from the junkyard and bolt it up to my rear end. To me stock is the best bang so if I have issues I can go to the local auto part store for parts. I would appreciate the help.
Re: 12 Bolt Rear End Disc Brake Conversion
« Reply #1 on: July 01, 2012, 06:15:30 pm »
     From your screen name I would assume you have an 87, 2wd or 4wd ?
« Reply #2 on: July 01, 2012, 06:44:20 pm »
I have a 2wd.
Offline slammed79
  • Thou shalt not drive stock
« Reply #3 on: July 01, 2012, 08:56:11 pm »
There is a bracket kit that utilizes astro rotors and gm d52 calipers, here is the link
 http://www.67-72chevytrucks.com/vboard/showthread.php?t=398352
You'll still need to get a adjustable proportioning valve, and other knick knacks to get it together
Praise the lowered
« Reply #4 on: July 01, 2012, 09:33:34 pm »
Awesome. Thanks. That's exactly what I wanted.
